Ir para o conteúdo principal
Informações sobre reparo e diagnóstico para a estação de energia portátil FixHub, a fonte de energia primária e a interface de controle para a linha de produtos FixHub da iFixit. Lançamento em outubro de 2024.
Has anyone had an issue with the battery erroring out?
Hello everyone,
I purchased the FixHub and it works wonderfully except for one small issue. When powering the iron off, after a while I will receive a battery charging halt error at 98%.
otherwise the iron works fine and discharges and charges as normal. Is this just a visual error, or is there something I should look into? I am on firmware 1.0.5
Thanks!
Esta é uma boa pergunta?
Pontuação 4
9 comentários
I’ve forward your issue to the iFixit product team for a response.
por
@danj, thank you.
@kaioshade, we're looking into it.
por
@krisrodriguez Thank you so much for the swift reply.
For some additional information, I am using an Anker Nano II 65W USB-C charger, with an Apple USB-C 240W cable. I have not tried any other chargers yet.
por
@kaioshade, you're welcome!
Thanks for the extra information. I have a follow-up question. Have you calibrated the battery? It's a button in the web UI. It's somewhat expected to have some variance up front with max charging percentages until this is done.
por
@krisrodriguez
I did not do the calibration when I got the unit (apologies, I didn't think to), but I did it tonight. I'll report back if it does happen again. Thanks for the info!
por
Exibir mais 4 comentários
Adicionar um comentário
1 resposta
Pergunta mais útil
Mine has only been used a handful of times, and the battery has been self discharging over a week by more than 10%
I also saw that the health percent for it is already down to 89%
Esta resposta foi útil?
Pontuação 1
3 comentários:
@omegatotal, have you tried updating to the latest firmware?
por
I just did through every version, now the battery health is MIA, and replaced with a setting for setting the max battery charge.
Also it appears that it is not respecting the inactivity/timeout that I had previously set to 30 minutes (its stayed on for multiple hours today after a couple of power cycles)
por
I just tried changing it to 29 minutes and back to 30 minutes after it stayed on without being touched for 2 hours. lets see what it does this time.
por
Adicionar a sua resposta
Cien será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 21
Ao todo: 401
