Ir para o conteúdo principal
Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 Perguntas Visualizar todos
Pergunta encerrada
Screen replacement/home button,please HELP!
Hey guys,
I am doing a screen replacement on my iphone again i put a red one on it a while back but i am doing another one and i hate doing the home button.but this is what i want to ask you. could i take the gasket to he 4s home button and do it like that and just lay the ribbon cable down and set it up just like the iphone 4s?thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
I wouldn't try that only because your button is going to be pretty hard to press, and might not work at all, if you use that gasket.
The iPhone 4 home button really isn't that difficult, use a splunger to gently peel underneath the ribbon where it first makes contact with the plastic. When connecting the pins use a pair of tweezers, they are a HUGE help.
Hope that solves your issue.
Esta resposta foi útil?
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 778
