Ir para o conteúdo principal
A terceira revisão do clássico Controle Sem Fio Xbox foi lançada em novembro de 2020, acompanhando o Xbox Series X e Series S. Este controle é compatível com versões anteriores dos consoles Xbox One e PCs.
Stick drift after replacing joystick module
I have replaced the right joystick module of an Xbox series controller as it had stick drift, but after replacing it the stick drift remains.
When replacing it I did notice some damage to the board so I’m now wondering if this is the cause, I’ve attached a photo so hopefully someone can let me know if that is likely the cause and if there’s anything that can be done.
Thanks, Luke
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
Hi Luke!
It look like that some traces are damaged.. this need to be recovered first. Did you already tried to clean it with alcohol? If it remains, then you do need to repair the traces and try again after!
If it’s still having drift after repairing the traces, then replace it again.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Hi Again! Thanks for getting back to me!
I have tried cleaning it with alcohol already and no luck. Fixing trace damage sounds like quite the ordeal, is it difficult? I’m quite new to soldering but happy to give it a try 😀
por
Hi! No problem!
Yes, it’s somewhat difficult. You need to scratch the trace with something sharp (or sand it) carefully, until you see the copper! Do this for both sides. Then solder a wire between it. So that a signal can come through again.
por
Maybe try adding a little bit more solder to those pins. Especially those bottom ones. Not to much tho just a tad
Pontuação 0
Adicionar a sua resposta
LukeResells será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 25
Últimos 30 dias: 76
Ao todo: 1,338
