Rears break light doesn't turn on
Rear break light doesn't turn on
Esta é uma boa pergunta?
@san38951 the very first thing you want to check all the fuses, the bulbs and the sockets for good connections. Next in line is your brake light switch. It is located under left side of dash, at the top of brake pedal. It's #3 in this image
Make sure that the plunger of the switch engages or disengage with the movement of the brake pedal. You can also use a multimeter or test light to see if the switch actually activates (closes contacts) when you depress the brake pedal. Because of the location of the switch it's a PITA to work on this but it is not to complicated. Of course, you always want to check all the fuses, the bulbs and the sockets for good connections.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 25
Ao todo: 392
1 comentário
Hello San.
We are going to need more information about what happened.
What happens when you press the brake?
This is most likely a blown fuse, faulty connector or a faulty break light sensor.
por N Kerr
