Ir para o conteúdo principal
O Samsung Galaxy Watch Active é um smartwatch projetado, desenvolvido e produzido pela Samsung Electronics, uma empresa sul-coreana de eletrônicos. Ele pode ser identificado pelo número do modelo SM-R500. Foi lançado em março de 2019.
need to replace the battery I think
After 2 months of wrecking my head, trying to use this Amazon.com: Ubrokeifixit Galaxy Watch Back Rear Lens Glass with Tape Replacement for Samsung Galaxy Watch 46mm SM-R800 R805/Galaxy Watch 42mm SM-R810 R815 Black(Rear Cover NOT Included) : Cell Phones & Accessories
There are 0 videos on how to use this kit... back started falling off. I was able to tape it on and it started working again, then just today it fell off again.
I have moved to the next step in trying to get this thing to work again, replacing the battery. What is need to do this.
Imagem
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hey there,
iFixit has a fairly comprehensive battery replacement guide for this device, which has a list of tools that you will need to replace the battery. I was also able to find a kit for the replacement battery that should have all you need, but I would double check to make sure that it is correct for your specific watch.
One last thing, I was also able to find a video guide for replacing the rear glass, that seems to be using the same kit you got. If you want to try replacing the backglass again, then that should be useful.
Best of luck to you.
Esta resposta foi útil?
Pontuação 1
16 comentários:
Thank you. Trying to save the battery replacement as a last resort. Still trying to figure out how to use the ubrokeit kit I bought on amazon.
Does Ifix it have a kit comparable to those on amazon, that you linked me?
por
@mnmacd iFixit has the tools, but sadly not the precut adhesive.
por
Thank you, would you mind linking the toolkit?
por
Phillips #00 Screwdriver
Will I need this as well? It came up as recommended with the tripoint
por
Exibir mais 11 comentários
Adicionar a sua resposta
mnmacd será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 24
Ao todo: 529
