Ir para o conteúdo principal
Repair and support for ceiling-mounted bladed fans.
20 Perguntas Visualizar todos
ceiling fan capacitor updated w/ pictures
replacement ceiling fan capacitor
My old capacitor is 250 V AC - 3 wires - 1 gray, 1 purple with a 2.85uF +/- 5% and 1 yellow with a 1.4 uF +/-5% - the only close one I can find has a red wire, purple 2.5 uF and yellow 1.5 uF. The model # (I believe it's the model #) is E183963. My question is can I use this with the lower uF on the purple (2.5 uF vs original 2.85) and slightly higher on the yellow (1.5 uF vs original 1.4). If not, can anyone recommend where I can find a more suitable replacement? Thank you much!
I found a capacitor on Amazon which I believe falls within the acceptable range. I've attached a picture of it. Please let me know if you think it is suitable. Thanks.
Posted this yesterday without pics...didn't know if my edit worked so I re-submitted. Sorry if not the right protocol.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@bobe27036 yes, the 2nd one will work. With capacitors, you can always go higher with the capacitance but never lower.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thanks much for your response! Greatly appreciated and I learned something!
por
Adicionar a sua resposta
Bob E. será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 12
Duração total: 47
