Ir para o conteúdo principal
A sétima iteração do iPod Touch da Apple, lançada em maio de 2019. Este modelo vem com até 256 GB de armazenamento e um processador A10. Número do modelo A2178.
Battery removal is never mentioned
In all of the answers after step 22 -all the guides instruct to set aside the battery to the left. None of them say actually how to remove the battery in full.
How it is done? Thanks all- I just need to service the battery.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
The battery is soldered to th logic board, so you’ll need to have some basic command of soldering to remove it and replace with a new one.
If you have a look at the battery, it’s not like the other components that have a connector which snaps into something on the board. There is some tape covering the contacts on the board. You’ll need to desolder the connector here and solder on a new battery.
Imagem de Replace a battery compatible with a 6th or 7th generation iPod touch model A1574 or A2178. Part #020-00425. Battery Model #A1641. 3.83 Volts (V).
Produto
iPod touch (6th and 7th Gen) Battery
$19.99
Esta resposta foi útil?
Pontuação 4
1 comentário:
Thanks- Fix-ability of this product seems low- I might not tackle it.
por
Adicionar a sua resposta
Paolo Alberto será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 16
Últimos 30 dias: 41
Ao todo: 514
