Ir para o conteúdo principal
O OnePlus Nord é um celular intermediário lançado em 2020. Ele possui uma tela Fluid AMOLED de 6,44" e 90 Hz, funciona com um processador Snapdragon 765G com 8/12 GB de RAM, 128/256 GB de armazenamento e oferece quatro câmeras traseiras e duas câmeras frontais.
Lock switch button not operating
My power button is not working
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Got the same problem on the OnePlus Nord 2 5G.
In My Opinion, it's a software issue and not Hardware. The Problem started straight after the software update to android 13 and the button works sometimes many times in a row without any problems. Sometimes, the 3rd, 5th or 15th click is registered (same position on the button, same pushing force...).
There is a workaround for automated shutdown/startups by scheduling a time. in case the shutdown really doesn't work, use this and set it to 1 minute in the future - and if you want to restart, set a turn-on time as well!
I had the problem that I couldn't turn it back on via buttonpress anymore and had to connect a charger to get the phone to boot once.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
harmeet nota será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 27
Ao todo: 458
