Ir para o conteúdo principal
Replacement case for kindle?
Hi,
My dog chewed on the side of my kindle and the black plastic on it is now partially gone in the corner. The kindle still works perfectly but the metal is exposed where it’s been bitten. I reached out to Amazon but alas the warranty has expired and they have no other solution for me. Anyone any ideas where I could get a new plastic cover?
Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
sorry for hear that, I got the same issue at the 2 bottom corners, suggest you to try AB glue or epoxy fill the hole and sand the corner use 400, 800, 1500 grit. good luck
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Caitlin Cruise será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 41
Ao todo: 460
