Ir para o conteúdo principal
Sixth generation of the iPad, released in March 2018. Available in Wi-Fi and LTE with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
iPad Home Button is overheating
It seems like I may have shorted out the battery on my iPad 6? The battery life is short, and now when I charge or am using it for a while (unplugged) the home button is significantly hot to the touch.
Is this something that I can fix by replacing the battery myself? Or is it too far gone?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
change the home button, I once had an iPad with same problem as yours, a simple home button swap fixed it. If this is your first time opening up an iPad, follow the guide on iFixit.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Gabriela Salazar será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 18
Ao todo: 247
