Ir para o conteúdo principal
Tv black screen problem but sound is heard
Black screen
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
@simranmondal start off with the easy stuff. Turn the TV to a channel where you can hear the sound. Next, use a flashlight and shine the beam at an angle against the screen. Do that in a darkened room. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed.
If you do not see anything, unplug your set and remove the back cover. Then visually check the boards for any obvious damaged components. Check all the wiring and unplug the wires and plug them back in, make sure they are properly seated. Post some images of all of your boards with your question. Use this guide Adicionar imagens a uma pergunta já existente for that so we can see what you see.
Let us know what you find out.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Simran mondal será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 10
Ao todo: 26
