Ir para o conteúdo principal
Modelo A1312 / Meados de 2010 / Core i3 de 3,2 GHz ou Core i5 de 2,8 e 3,6 GHz ou Core i7 de 2,93 GHz, ID iMac11,3
My problem is at Step 3
My problem is at Step 3, when I press the power button, the LED 2 lights up but when I leave the power button it turns off and the system also does not turn on. I have followed all the other steps after that and still nothing. Please suggest/help.
Thanks in advance.
Esta é uma boa pergunta?
Pontuação 0
2 comentários
What happened with your system?
por
Hey there, Step 3 of what guide?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Without more information it's hard to be certain what's gone wrong, but if you're only getting the first two diagnostic LEDs, then you may have an issue with the video card (something that is known to fail on the 2010 model). If the system is powering off immediately after releasing the power button, though, then that may indicate some larger issue, either with the power supply or the main logic board. Good luck!
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Dharmesh Thakker será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 12
Ao todo: 170
