Can I fix the internal microphone?
my internal microphone stopped working, can I replace it?
I did remove the display and did not cover the microphone hole since I've not applied the adhesive strips yet, I also believe the microphone is connected properly, is a small connector on the bottom of the logic board.
Esta é uma boa pergunta?
3 comentários
You appear to have the 2020 model as that has a different microphone cable setup if the image is your system iMac 27" Retina 5K Microphone (20). Reference Step 50 from this guide iMac Intel 27" Retina 5K Display 2020 Logic Board Replacement I see you’ve put the tapes on double check the mic hole as it’s very easy to block. If the sound is muffled that’s the issue
por Dan
its not muffled at all. not even tapping on it does anything
por Carlos Orozco
@carlosoroz68743 - New mic then.
por Dan
