Ir para o conteúdo principal
iMac 27" 2017 Blade SSD Replacement
O que você precisa
  1. iMac 27" 2017 Blade SSD Replacement, Install the service wedge: passo 1, imagem 1 %32
    Ferramenta utilizada neste passo:
    iMac Intel 27" Cardboard Service Wedge
    Pergunte ao FixBot
    Comentar
  2. iMac 27" 2017 Blade SSD Replacement, Insert an opening tool: passo 2, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement, Insert an opening tool: passo 2, imagem 2 %32 iMac 27" 2017 Blade SSD Replacement, Insert an opening tool: passo 2, imagem 3 %32
    • Starting on the left of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear case.
    • The hub on the iMac Opening Tool will keep you from pushing the wheel in too far. If using a different tool, insert it no more than 3/8" (9.5 mm) into the display. You risk severing antenna cables and causing serious damage if you insert the tool too far.
    Pergunte ao FixBot
    Comentar
  3. iMac 27" 2017 Blade SSD Replacement, Slice through the display adhesive: passo 3, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement, Slice through the display adhesive: passo 3, imagem 2 %32 iMac 27" 2017 Blade SSD Replacement, Slice through the display adhesive: passo 3, imagem 3 %32
    • Use the tool like a pizza cutter—roll it along through the gap, and it will cut the foam adhesive through the center.
    • Be sure to always push with the handle behind the cutting wheel. If you pull, the wheel might get pulled out of the handle.
    • Run the tool up along the left side of the display.
    Pergunte ao FixBot
    Comentar
  4. iMac 27" 2017 Blade SSD Replacement, Cut through the remaining adhesive: passo 4, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement, Cut through the remaining adhesive: passo 4, imagem 2 %32 iMac 27" 2017 Blade SSD Replacement, Cut through the remaining adhesive: passo 4, imagem 3 %32
    • Continue wheeling the tool up around the top left corner.
    Pergunte ao FixBot
    Comentar
  5. iMac 27" 2017 Blade SSD Replacement: passo 5, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement: passo 5, imagem 2 %32
    • Cut the adhesive along the top left of the display.
    Pergunte ao FixBot
    Comentar
  6. iMac 27" 2017 Blade SSD Replacement: passo 6, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement: passo 6, imagem 2 %32
    • Continue along the top of the display.
    • You may want to run the tool back and forth through what you've already cut a few times, to ensure you get as much of the adhesive separated as possible.
    Pergunte ao FixBot
    Comentar
  7. iMac 27" 2017 Blade SSD Replacement: passo 7, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement: passo 7, imagem 2 %32 iMac 27" 2017 Blade SSD Replacement: passo 7, imagem 3 %32
    • Push the tool around the top right corner of the display.
    Pergunte ao FixBot
    Comentar
  8. iMac 27" 2017 Blade SSD Replacement: passo 8, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement: passo 8, imagem 2 %32
    • Wheel the tool down along the right side of the display.
    Pergunte ao FixBot
    Comentar
  9. iMac 27" 2017 Blade SSD Replacement: passo 9, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement: passo 9, imagem 2 %32
    • Finish pushing the opening tool to the bottom of the right side of the display.
    • At this point, you'll want to run the tool back around the entire display, to ensure you cut as much adhesive as possible.
    Pergunte ao FixBot
    Comentar
  10. iMac 27" 2017 Blade SSD Replacement, Separate the display: passo 10, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement, Separate the display: passo 10, imagem 2 %32 iMac 27" 2017 Blade SSD Replacement, Separate the display: passo 10, imagem 3 %32
    Plastic Cards
    $2.99
    • While the opening tool did the lion's share of the work, the display will still be slightly adhered to the case. A plastic card will be necessary to free up the last of this adhesive.
    • Set the iMac face-up on a table.
    • Starting from the top right corner of the iMac, insert a plastic card between the display and frame.
    • Be careful not to insert it more than 3/8" (9.5 mm), or you may damage internal components.
    Pergunte ao FixBot
    Comentar
  11. iMac 27" 2017 Blade SSD Replacement: passo 11, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement: passo 11, imagem 2 %32
    • Gently twist the plastic card to open the space between the display and frame, and cut any remaining adhesive near the corner.
    • Using too much force will crack the glass. Work carefully, and don't try to create a gap any larger than about 1/4" (6 mm).
    Pergunte ao FixBot
    Comentar
  12. iMac 27" 2017 Blade SSD Replacement: passo 12, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement: passo 12, imagem 2 %32 iMac 27" 2017 Blade SSD Replacement: passo 12, imagem 3 %32
    • Be sure to stop cutting before the iSight camera in this step, or you may damage it.
    • Slide the card toward the center of the display, to cut any remaining adhesive.
    Pergunte ao FixBot
    Comentar
  13. iMac 27" 2017 Blade SSD Replacement: passo 13, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement: passo 13, imagem 2 %32
    • Put the card into the corner again and let it stay there to keep the adhesive from resettling.
    Pergunte ao FixBot
    Comentar
  14. iMac 27" 2017 Blade SSD Replacement: passo 14, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement: passo 14, imagem 2 %32 iMac 27" 2017 Blade SSD Replacement: passo 14, imagem 3 %32
    • Insert a second card into the gap between the display and frame in the top left corner.
    Pergunte ao FixBot
    Comentar
  15. iMac 27" 2017 Blade SSD Replacement: passo 15, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement: passo 15, imagem 2 %32
    • Gently twist the card, slightly increasing the space between the display and frame.
    • As with the other side, move slowly to allow the adhesive to break, and be careful not to over-stress the display glass.
    Pergunte ao FixBot
    Comentar
  16. iMac 27" 2017 Blade SSD Replacement: passo 16, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement: passo 16, imagem 2 %32 iMac 27" 2017 Blade SSD Replacement: passo 16, imagem 3 %32
    • Slide the plastic card toward the center, again stopping just before the iSight camera.
    Pergunte ao FixBot
    Comentar
  17. iMac 27" 2017 Blade SSD Replacement: passo 17, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement: passo 17, imagem 2 %32
    • Insert the card back into the top left corner.
    Pergunte ao FixBot
    Comentar
  18. iMac 27" 2017 Blade SSD Replacement: passo 18, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement: passo 18, imagem 2 %32 iMac 27" 2017 Blade SSD Replacement: passo 18, imagem 3 %32
    • With the cards inserted as shown near the corners, gently twist the cards to increase the gap between display and case.
    • If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the adhesive in the problem area.
    • Begin to lift the top of the display up from the frame.
    • Only lift the display a few inches—it is still attached to the iMac by data and power cables.
    Pergunte ao FixBot
    Comentar
  19. iMac 27" 2017 Blade SSD Replacement, Disconnect the display cables: passo 19, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement, Disconnect the display cables: passo 19, imagem 2 %32
    • While holding the display up with one hand, use the other to unplug the display power cable.
    • Lift the display up enough to have easy access to the connections, but not so much that you stretch the cables and stress their connections (about 8").
    Pergunte ao FixBot
    Comentar
  20. iMac 27" 2017 Blade SSD Replacement: passo 20, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement: passo 20, imagem 2 %32 iMac 27" 2017 Blade SSD Replacement: passo 20, imagem 3 %32
    • Flip up the metal retaining bracket on the display data cable.
    • Disconnect the display data cable.
    • This is a delicate connection that can easily be broken. Be sure to pull the display data cable connector straight out of its socket, toward the top of the iMac.
    Pergunte ao FixBot
    Comentar
  21. iMac 27" 2017 Blade SSD Replacement, Lift the display: passo 21, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement, Lift the display: passo 21, imagem 2 %32
    • Lift the display up to a near-vertical position.
    • At this point there is still a strip of adhesive along the bottom of the display that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
    Pergunte ao FixBot
    Comentar
  22. iMac 27" 2017 Blade SSD Replacement, Remove the remaining adhesive: passo 22, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement, Remove the remaining adhesive: passo 22, imagem 2 %32 iMac 27" 2017 Blade SSD Replacement, Remove the remaining adhesive: passo 22, imagem 3 %32
    • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red).
    • Grasp the small tab at the end of one of the bottom edge display adhesive strips and pull the adhesive toward the top of the iMac to remove it.
    • Repeat this step with the other adhesive strip and remove it.
    • If either adhesive strip breaks before it's removed, use a plastic card to slice through the remaining adhesive.
    Pergunte ao FixBot
    Comentar
  23. iMac 27" 2017 Blade SSD Replacement, Remove the display: passo 23, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement, Remove the display: passo 23, imagem 2 %32 iMac 27" 2017 Blade SSD Replacement, Remove the display: passo 23, imagem 3 %32
    • Be very careful handling the display—it's big, heavy, and made of glass. The display has fragile edges. Avoid lifting the display by the corners.
    • Lift the display up from the frame and remove it from the iMac. Lay the display face down on a flat, soft surface.
    • It may be necessary to slowly lift from one side, to peel against the remaining adhesive.
    • After the adhesive is cut, it cannot be used to re-seal the display in place. Follow this guide when your repair is complete to replace the adhesive strips that secure the display to the rear enclosure.
    Pergunte ao FixBot
    Comentar
  24. iMac 27" 2017 Blade SSD Replacement, Remove the support bracket: passo 24, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement, Remove the support bracket: passo 24, imagem 2 %32
    • Use a Phillips screwdriver to remove the nine 3.2 mm screws securing the support bracket.
    • You may need to peel up the display adhesive lining the bottom edge of the iMac enclosure to access the screws.
    Pergunte ao FixBot
    Comentar
  25. iMac 27" 2017 Blade SSD Replacement: passo 25, imagem 1 %32
    • Remove the lower support bracket (a.k.a. "chin strap") from the iMac enclosure.
    • How to easily reinstall this support bracket:
    • Position the bracket diagonally.
    • Secure the rightmost screw enough to hold the bracket in place; keep it loose for now so the bracket can pivot.
    • Swing the left side of the bracket down until it sits horizontally in its original position.
    • Starting with the leftmost screw, install and tighten the remaining screws.
    Pergunte ao FixBot
    Comentar
  26. iMac 27" 2017 Blade SSD Replacement, Remove the left speaker: passo 26, imagem 1 %32
    • Remove two 10 mm T10 screws.
    Pergunte ao FixBot
    Comentar
  27. iMac 27" 2017 Blade SSD Replacement: passo 27, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement: passo 27, imagem 2 %32 iMac 27" 2017 Blade SSD Replacement: passo 27, imagem 3 %32
    • Unplug the left speaker cable by pulling it straight up out of its socket on the logic board.
    • De-route the cable from the gap between the hard drive and logic board.
    • If the gap between the hard drive and logic board is too narrow for the speaker cable, disconnect it and leave the cable in place.
    Pergunte ao FixBot
    Comentar
  28. iMac 27" 2017 Blade SSD Replacement: passo 28, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement: passo 28, imagem 2 %32 iMac 27" 2017 Blade SSD Replacement: passo 28, imagem 3 %32
    • Be careful not to touch any solder joints on the back of the power supply. Capacitors may be charged enough to give you a dangerous shock.
    • Use a spudger to disconnect the power button connector from its socket on the logic board.
    Pergunte ao FixBot
    Comentar
  29. iMac 27" 2017 Blade SSD Replacement: passo 29, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement: passo 29, imagem 2 %32
    • Lift the left speaker straight up, until the power button cable is exposed (about 0.5 inches).
    Pergunte ao FixBot
    Comentar
  30. iMac 27" 2017 Blade SSD Replacement: passo 30, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement: passo 30, imagem 2 %32 iMac 27" 2017 Blade SSD Replacement: passo 30, imagem 3 %32
    • Gently de-route the power button cable from its groove in the left speaker.
    Pergunte ao FixBot
    Comentar
  31. iMac 27" 2017 Blade SSD Replacement: passo 31, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement: passo 31, imagem 2 %32 iMac 27" 2017 Blade SSD Replacement: passo 31, imagem 3 %32
    • Lift the left speaker straight up and remove it from the iMac.
    • If the gap between the hard drive and logic board was too narrow to free the speaker cable earlier, gently pull it free as you remove the speaker.
    • Push from the connector end as you pull from the speaker end to thread the cable under the hard drive's right bracket.
    Pergunte ao FixBot
    Comentar
  32. iMac 27" 2017 Blade SSD Replacement, Remove the hard drive: passo 32, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement, Remove the hard drive: passo 32, imagem 2 %32
    • Pull straight up on the SATA data/power cable to disconnect it from the drive.
    Pergunte ao FixBot
    Comentar
  33. iMac 27" 2017 Blade SSD Replacement: passo 33, imagem 1 %32
    • Remove two 7.3 mm T8 screws securing the left hard drive bracket to the rear case.
    Pergunte ao FixBot
    Comentar
  34. iMac 27" 2017 Blade SSD Replacement: passo 34, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement: passo 34, imagem 2 %32 iMac 27" 2017 Blade SSD Replacement: passo 34, imagem 3 %32
    • Grab the hard drive and left hard drive bracket together.
    • Tilt the left side up away from the rear case, and slide the assembly to the left.
    • Remove the hard drive and left hard drive bracket from the iMac.
    Pergunte ao FixBot
    Comentar
  35. iMac 27" 2017 Blade SSD Replacement: passo 35, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement: passo 35, imagem 2 %32
    • Remove the left hard drive bracket.
    Pergunte ao FixBot
    Comentar
  36. iMac 27" 2017 Blade SSD Replacement, Remove the power supply: passo 36, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement, Remove the power supply: passo 36, imagem 2 %32
    • When working on the power supply, be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
    • Disconnect the power supply control cable from the power supply.
    Pergunte ao FixBot
    Comentar
  37. iMac 27" 2017 Blade SSD Replacement: passo 37, imagem 1 %32
    • Remove the following four screws securing the power supply to the rear case (size T8 or T10 depending on the exact model):
    • Two 23.7 mm Torx screws
    • Two 7.3 mm Torx screws
    Pergunte ao FixBot
    Comentar
  38. iMac 27" 2017 Blade SSD Replacement: passo 38, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement: passo 38, imagem 2 %32 iMac 27" 2017 Blade SSD Replacement: passo 38, imagem 3 %32
    • Do not attempt to remove the power supply from the case; it is still attached to the logic board by two cables.
    • Move the power supply board towards the left edge of the case and up to free it from the notch in the logic board.
    Pergunte ao FixBot
    Comentar
  39. iMac 27" 2017 Blade SSD Replacement: passo 39, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement: passo 39, imagem 2 %32
    • Depress the tab on the DC power cable connector, then pull it straight out of its socket on the back of the logic board.
    • If the cable is too difficult to disconnect, you can remove the power supply board and motherboard together.
    Pergunte ao FixBot
    Comentar
  40. iMac 27" 2017 Blade SSD Replacement: passo 40, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement: passo 40, imagem 2 %32 iMac 27" 2017 Blade SSD Replacement: passo 40, imagem 3 %32
    • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
    • Flip the top of the power supply towards you, like opening a mailbox, to reveal the AC inlet cable connector.
    • Disconnect the AC inlet cable connector.
    Pergunte ao FixBot
    Comentar
  41. iMac 27" 2017 Blade SSD Replacement, Remove the right speaker: passo 41, imagem 1 %32
    • Remove two 9.8 mm T8 screws.
    Pergunte ao FixBot
    Comentar
  42. iMac 27" 2017 Blade SSD Replacement: passo 42, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement: passo 42, imagem 2 %32
    • Gently rock the right speaker slightly to the right, to allow access to its cable's connection on the logic board.
    Pergunte ao FixBot
    Comentar
  43. iMac 27" 2017 Blade SSD Replacement: passo 43, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement: passo 43, imagem 2 %32 iMac 27" 2017 Blade SSD Replacement: passo 43, imagem 3 %32
    • Use a spudger to loosen the right speaker cable's connector from its socket on the logic board.
    • Pull the connector to the right to remove it from its socket.
    Pergunte ao FixBot
    Comentar
  44. iMac 27" 2017 Blade SSD Replacement: passo 44, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement: passo 44, imagem 2 %32 iMac 27" 2017 Blade SSD Replacement: passo 44, imagem 3 %32
    • Lift the speaker straight up and remove it from the iMac.
    Pergunte ao FixBot
    Comentar
  45. iMac 27" 2017 Blade SSD Replacement, Remove the fan: passo 45, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement, Remove the fan: passo 45, imagem 2 %32 iMac 27" 2017 Blade SSD Replacement, Remove the fan: passo 45, imagem 3 %32
    • Use the tip of a spudger to disconnect the fan cable's connector from its socket on the logic board.
    Pergunte ao FixBot
    Comentar
  46. iMac 27" 2017 Blade SSD Replacement: passo 46, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement: passo 46, imagem 2 %32
    • Peel the black tape connecting the fan to the exhaust duct back slightly.
    • Leave the tape in place on the exhaust duct—you only need to expose the joint to free the fan.
    Pergunte ao FixBot
    Comentar
  47. iMac 27" 2017 Blade SSD Replacement: passo 47, imagem 1 %32
    • Remove three 12.4 mm T10 screws securing the fan to the rear case.
    Pergunte ao FixBot
    Comentar
  48. iMac 27" 2017 Blade SSD Replacement: passo 48, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement: passo 48, imagem 2 %32
    • Remove the fan from the iMac.
    Pergunte ao FixBot
    Comentar
  49. iMac 27" 2017 Blade SSD Replacement, Remove the logic board: passo 49, imagem 1 %32
    • Use a T5 Torx screwdriver to remove the two 4 mm screws securing the AirPort/Bluetooth antenna cables.
    Pergunte ao FixBot
    Comentar
  50. iMac 27" 2017 Blade SSD Replacement: passo 50, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement: passo 50, imagem 2 %32 iMac 27" 2017 Blade SSD Replacement: passo 50, imagem 3 %32
    • Use the point of a spudger to disconnect each of the four antenna connectors from the AirPort/Bluetooth card.
    • Note the original positions for each connector when reconnecting the cables. From left to right on the card, the antennas are connected in the following order:
    • Leftmost
    • Top
    • Upper right
    • Lower right
    Pergunte ao FixBot
    Comentar
  51. iMac 27" 2017 Blade SSD Replacement: passo 51, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement: passo 51, imagem 2 %32 iMac 27" 2017 Blade SSD Replacement: passo 51, imagem 3 %32
    • This is a delicate connection that can be easily broken.
    • Flip up the metal retaining bracket on the iSight camera cable.
    • Pull the camera cable connector straight out of its socket, toward the top of the iMac.
    Pergunte ao FixBot
    Comentar
  52. iMac 27" 2017 Blade SSD Replacement: passo 52, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement: passo 52, imagem 2 %32 iMac 27" 2017 Blade SSD Replacement: passo 52, imagem 3 %32
    • Use the flat end of a spudger to disconnect the headphone jack cable connector from its socket on the logic board.
    • Gently push the cable out of the way.
    Pergunte ao FixBot
    Comentar
  53. iMac 27" 2017 Blade SSD Replacement: passo 53, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement: passo 53, imagem 2 %32 iMac 27" 2017 Blade SSD Replacement: passo 53, imagem 3 %32
    • Use the tip of a spudger to flip open the retaining flap on the microphone ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Use tweezers to gently pull the microphone ribbon cable straight out of its socket.
    Pergunte ao FixBot
    Comentar
  54. iMac 27" 2017 Blade SSD Replacement: passo 54, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement: passo 54, imagem 2 %32
    • Remove the following screws securing the logic board:
    • Two 23.7 mm T8 screws
    • One 20.1 mm T25 spacer screw
    • One 17.6 mm T8 screw
    • One 7.2 mm T8 screw
    • Three 7.1 mm T8 screws
    • One captive T8 screw
    • This screw is beneath a hole in the logic board. If you aren't using an iFixit driver, you may need an extension or a screwdriver with a longer shaft.
    Pergunte ao FixBot
    Comentar
  55. iMac 27" 2017 Blade SSD Replacement: passo 55, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement: passo 55, imagem 2 %32 iMac 27" 2017 Blade SSD Replacement: passo 55, imagem 3 %32
    • Pull the hard drive SATA cable and connector through the right hard drive bracket. Move the cable to the right side of the iMac, out of the way of the exhaust port.
    • Don't attempt to completely remove the cable—it can't be removed just yet, but will get in the way of removing the logic board.
    Pergunte ao FixBot
    Comentar
  56. iMac 27" 2017 Blade SSD Replacement: passo 56, imagem 1 %32
    • Use a T8 Torx screwdriver to remove the two 5.6 mm screws from the top of the heat sink exhaust duct.
    Pergunte ao FixBot
    Comentar
  57. iMac 27" 2017 Blade SSD Replacement: passo 57, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement: passo 57, imagem 2 %32 iMac 27" 2017 Blade SSD Replacement: passo 57, imagem 3 %32
    • When removing and installing the logic board, take care not to damage the delicate microphone ribbon cable at the bottom left of the board.
    • Tilt the logic board slightly forward.
    • Lift the logic board straight up and out of the iMac. Be careful not to snag it on any of the screw posts attached to the inside of the rear case.
    Pergunte ao FixBot
    Comentar
  58. iMac 27" 2017 Blade SSD Replacement: passo 58, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement: passo 58, imagem 2 %32
    • When reassembling your iMac, be very careful to align the exterior I/O ports correctly. The logic board can sit crooked even when secured with all its screws.
    • You can use a USB flashdrive or ethernet cable to ensure the logic board is seated correctly while you screw it in.
    Pergunte ao FixBot
    Comentar
  59. iMac 27" 2017 Blade SSD Replacement, SATA Cable: passo 59, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement, SATA Cable: passo 59, imagem 2 %32 iMac 27" 2017 Blade SSD Replacement, SATA Cable: passo 59, imagem 3 %32
    • Pull up on the SATA power cable connector to disconnect it.
    • Unplug the SATA data cable connector by depressing its locking tab and pulling straight up on the connector.
    • Remove the SATA cable from the logic board assembly to get it out of the way and prevent it from being damaged.
    Pergunte ao FixBot
    Comentar
  60. iMac 27" 2017 Blade SSD Replacement, Blade SSD: passo 60, imagem 1 %32
    • Remove the single 5.3 mm T8 screw securing the SSD to the logic board.
    Pergunte ao FixBot
    Comentar
  61. iMac 27" 2017 Blade SSD Replacement: passo 61, imagem 1 %32 iMac 27" 2017 Blade SSD Replacement: passo 61, imagem 2 %32 iMac 27" 2017 Blade SSD Replacement: passo 61, imagem 3 %32
    • To avoid damaging its socket, do not lift the end of the SSD above about 15˚.
    • Lift the end of the SSD up slightly and pull it straight out of its socket on the logic board.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
    Pergunte ao FixBot
    Comentar
Conclusão
49 outras pessoas executaram este guia.
Adam O'Camb
Membro desde: 04/11/15
223.264 Reputação
Autoria de 416 guias
11Comentários do guia
is there any way to replace the I.O without swapping the motherboard?
Crystal Haugh - Responder Compartilhar
From cutting through the adhesive to the smoke test this was just under a four hour job for me. One adhesive strip left a complete layer of glue on one side of the screen, and it took me the better part of an hour, about half my supply of wipes, and a plastic razor blade just to clean that one edge up. I’d break the time down as: removing, cleaning, or reapplying adhesives, 2 hours; non-adhesive disassembly, 50 minutes; reassembly, 40 minutes; “oh crap, where’s that tool?” 15 minutes; and about 10 minutes for cleanup, including vacuuming out the fan, heat sink, and vents.
Ed Poe - Responder Compartilhar
Hi there, I need your professional help. I followed all instructions to change my iMac 2017 27" 5K fusion drive with a Samsung EVO 970 PLUS 2TB (with upgraded firmware) for macOS bootable drive and extra EVO 860 SSD 4TB data drive. Then updated to Monterey. My first test was 1200w 2900r, which was different from the youtube video which was roughly 3Krw. Why was that? Then after a few days of work, the mac froze during youtube watch and again during excel spreadsheet, and restarted with a "?" in a folder. I made an online hardware check all OK, then performed first aid, and again all OK. Then rebooted to the same "?" screen. And then rebooted again and now it works. So far! I see in the system prefs - Link Width x1. I made the speed test again and the reading now is roughly 700rw. Screenshots and sys error report bellow. What have I done wrong? And what to do to fix it all? Thanks!
Peter Lane - Responder Compartilhar
Did anyone already thought or experienced to just cut out a square at the back of the frame? its not elegant but my imacs back just faces the wall :) for thermal reasons i can imagine just to stick it back.
dave777 - Responder Compartilhar
It's a shame Apple couldn't manage to put this on the front of the logic board--such a pain (by design).
maccentric - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 101
Últimos 30 dias: 526
Ao todo: 61,484
