Ir para o conteúdo principal
Informações de reparo e desmontagem para o smartphone Android topo de linha da Samsung, o S20 Ultra, lançado em março de 2020.
My phone camera failed problem
Dear Valuable Mobile Mechanic Brothers. My phone camera is suddenly not working. My phone is samsung s20 ultra. When you open the camera, the message "Camera Felt" appears. What should I do in this situation please?Dear Valuable Mobile Mechanic Brothers. My phone camera is suddenly not working. My phone is samsung s20 ultra. When you open the camera, the message "Camera Felt" appears. What should I do in this situation?
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
@rashedulis70858 what have you tried? Have you checked if your camera still responds in Safe Mode
por Compartilhar
Adicionar um comentário
1 resposta
I found a work around. I downloaded an app called Ai capture. It allows you to manually select which camera you want to use before it launches it.
I've noticed that with mine, everything but the rear secondary camera labeled as hardware 2, the one that's the 100x, and it will work.
Other than that, someone at Samsung dropped the ball.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Rashedul Islam Abir será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 27
Ao todo: 378
