Ir para o conteúdo principal
The Droid Razr is an Android-based, 4G LTE-capable smartphone designed by Motorola.
60 Perguntas Visualizar todos
Pergunta encerrada
How can I reboot my razr?
Hi! I was charging my droid razr and all of the sudden, it goes off and it wont do anything! Tried to reboot it by pressing and holding power button and volume button but it wont turn on. Please help!!!
Esta é uma boa pergunta?
Pontuação 0
1 comentário
I tries to reset using volume down and power button but it didn't work what other options do I have
por
Adicionar um comentário
3 respostas
Pergunta mais útil
Sara, I would try this first. Press and hold the Volume Down and Power buttons on the right side of the device for about 10 seconds. This should restart your phone.
Esta resposta foi útil?
Pontuação 3
4 comentários:
I had the same problem and it worked for me. Thanks.
Pete
por
Thank you so much I was starting to freak out
por
Worked like a charm, Stopped my husband from going to Verizon store and acting like a crazed man....Thanks
por
I had to hold mine down for about 30 - 45 seconds, letting go when my fingers couldn't take it any more. Then about 7 - 10 seconds later it rebooted.
por
it helped me also thank you so much too.
Pontuação 0
Held them down for over a minute and still nothing happened. It is stuck on the home screen can't unlocked it won't let the numbers key in just keeps repeating commands
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 3,673
