Ir para o conteúdo principal
Também conhecido como PS one ou PSOne, este dispositivo é a versão slim do PlayStation original, lançado em 2000.
Weird graphical issue stripes
I have a stripe going down the middle of my screen was hoping someone may know a fix i could do to solve the issue.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi!
Yeah, I recognize this issue and it's not good.
Your GPU is probably dying and as it's hard (almost impossible) find the GPU chip, you probably do need to replace the motherboard to get this fixed.... Is it modded with a modchip? If yes, please remove this first to see if it's solved or not. Probably this won't solve it, so a motherboard replacement is required. Motherboards are also very hard to find.. So you can buy a donor-broken motherboard with other issues, so you can take the component of it. This is very hard and you do need solder experience.
Sorry for the bad news...
Esta resposta foi útil?
Pontuação 1
4 comentários:
That is fine I've got a donor I just wanted to see what the possible issue could be ill give that a go thank you :3
por
My pleasure! If you need anything else, please let us know :)! Good luck with the repair!
por
Well the only other question i'd have is are the other gpu chips interchangeable or do i need that models chip to replace it?
por
You do need the exact model unfortunately..
por
Adicionar a sua resposta
Kurono será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 17
Ao todo: 295
