Ir para o conteúdo principal
2,26 ou 2,4 GHz / Estrutura monobloco de plástico branco
My MacBook doesn't turn on.
Hello,
I will start with the fact that this device doesnt exist and thats because I dont know the model. I bought the laptop for 30 bucks and it came without hdd and the adapter for it apparently and the cover was some makeshift fake thing. One two pin connector is broken but doesnt short.
The power adapter is missing the part for the outlet and I’m using my ps5 power adapter to fix this issue but even after that the adapter doesn’t show light and the laptop doesn’t turn on.
The motherboard has some pins which I think should be shorted in order for the laptop to work but the makeshift cover has metal exposed to shorten them. I am asking you to help me with this and also identify if you can the model. Use the photos to help me please. Also please reach to me if you want to help me further on diacord: jordi.joeyson.
Thanks!
Imagem
Imagem
Imagem
Imagem
Imagem
Imagem
Imagem
Imagem
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Yes this is a A1342 system. The logic board EMC number validates it.
Here’ the guides you can reference MacBook Unibody A1342
And here’s more details on your system Apple MacBook "Core 2 Duo" 2.13 13" (White-09) Specs
por
Adicionar um comentário
1 resposta
Pergunta mais útil
@yaniyonchev your computer is a MacBook Model A1342 (EMC 2350) MacBook6,1 "Core 2 Duo" 2.26 13" (Unibody/Late 2009-Early 2010)
The part missing from your MagSafe is the power plug adapter and I assume you are talking about the Power-On Pads. Best place to check for those is always on here
Imagem
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Яни Йончев será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 8
Ao todo: 155
