Ir para o conteúdo principal
A 32" Roku TV released by TCL in 2018.
Volume issues down and up at any time
Volume issue down and up at any time
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Hi, it would be helpful if you can be a bit more specific like:
“it does it by itself”
“Volume doesn’t change going up or down”
“Other symptoms”
por
Adicionar um comentário
1 resposta
Solução escolhida
@bekaluyitbarek couple of things you want to try. First you want to go into your audio settings. There should be a "Advanced Settings" area. Click on that and then turn the "Auto Volume Control" off.
Next remove the battery from your TV while it is turned on and see if the volume has normalized.
Let us know what you find out.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Bekalu Yitbarek será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 24
Ao todo: 241
