Ir para o conteúdo principal
Repair guides and support for physical works of art such as paintings, photographic prints, pots, and tapestries.
5 Perguntas Visualizar todos
I’m from the uk what is “cardstock”?
I have no clue what you are saying when you say “cardstock” card? Cardboard? Some example of what card is the correct weight and thickness would be extremely helpful… or better still a link to an ideal piece of card that I can acquire in the UK please
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
Its a thicker piece of paper that is stronger than normal paper but not quite cardboard, its the same stuff that buisness cards, playing cards, etc. are made out of hence "cardstock"
Construction paper is very similar in use and usability, you can probably get it at your local arts and crafts store, if not here is a 300 piece 8.5 by 11 inch box on amazon
Esta resposta foi útil?
Pontuação 2
Hi @nics93686
Cardstock is another term that refers to a grade of paper, usually determined by its weight
Here's a guide showing the different paper weights and their uses.
Search online for cardstock UK suppliers to find one that suits you best. (examples only.
Pontuação 1
Adicionar a sua resposta
Nics será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 37
