There is a black line on my screen
there is a black line on my screen the drivers are updated. screenshot dontshow the line.
Update (09/08/24)
this is the screen
Esta é uma boa pergunta?
this is the screen
@deryaduygut2145 that will depend on how thick this line is. If it is a thin line the issue is most commonly a TAB error. That is where one of the COF ribbon cables looses connection to the LCD screen. This can't be fixed by us DIY'er since it is attached via a special process. Sometimes applying pressure to the ribbon will close the contact and the line will disappear. If it is a thick line it is possible that this is a LVDS cable issue. Post an image of what your screen shows with your Question. That way we can see what you. For now, it seems like you will need a new display to fix this.
Use the Lenovo Ideapad 5 Hardware Maintenance Manual to work on it. Page 58 will tell you how to replace the LCD
Adicionar imagens a uma pergunta já existente
@deryaduygut2145 that is definitely a cracked screen there is no fixing it. You will need a new LCD.
Esta resposta foi útil?
You for sure will need a new screen. That "line" is caused by an internal crack.
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Ao todo: 100
