Samsung A30 sensor proximidad
Sensor proximidad A30
Atualizar (09/07/24)
No funciona al alejar de la cara.
Esta é uma boa pergunta?
@marceloedu43554 make sure that you have updated all your software. Next you want to go ahead and try your proximity sensor in Safe mode. You get your phone in safe mode by:
Press and hold the. Power button. and. Volume down button. ... Touch and hold. Power off. until the 'Safe mode' prompt appears then release.
To confirm, tap. Safe mode. . ...
Once it is in Safe mode you want to make sure that Airplane Mode is turned off. Now try your sensor. If it works in Safe mode, then the issue is actually a bad 3rd party App you downloaded. You must uninstall those until you find the one that may have caused this.
If your proximity sensor does not work in Safe mode either, try to see if you can get into the hardware testing mode by dialing *#0*# ➡ Samsung Hardware Diagnostic Test Menu Here you can use the menu for the sensor test and see if it passes.You can also try and dial *#77692# which will take you to the proximity Sensor checking
If that does not work or the sensor does not pass, it may actually be time to replace it. Since iFixit does not yet have a specific guide for this, Use something like this video The A30 uses a TCS3701 sensor and I have not yet been able to find a replacement.
Of course, you could check the proximity sensor according to the Samsung flowchart
Since we do not know which exact version your A30 is, you will find that the location for some of the components is different. This document A30 Component Layout All shows all of them. Use the search function of your PDF reader to locate the component to check i.e. "R3004" that way you can check all of those.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@marceloedu43554 certifica-te de que actualizaste todo o teu software. A seguir, tens de experimentar o sensor de proximidade em modo de segurança. Coloca o teu telefone em modo de segurança: Mantém premido o botão. Botão de alimentação. e. Mantém premido o botão de ligar/desligar. Toca e mantém premido. Desligar. até aparecer a mensagem “Modo de segurança” e, em seguida, solta-a. Para confirmar, toca em. Modo de segurança. . ...
Quando estiver no modo de segurança, certifica-te de que o modo de avião está desligado. Agora experimenta o teu sensor. Se funcionar no modo de segurança, então o problema é uma má aplicação de terceiros que descarregaste. Tens de as desinstalar até encontrares a que pode ter causado o problema.
Se o nosso sensor de proximidade também não funcionar em modo de segurança, tenta ver se consegues entrar no modo de teste de hardware, marcando *#0*# ➡ Menu de teste de diagnóstico de hardware da Samsung Aqui podes usar o menu para o teste do sensor e ver se passa. Também podes tentar marcar *#77692# que te levará à verificação do sensor de proximidade
Se isso não funcionar ou se o sensor não passar, talvez seja altura de o substituíres. Como o iFixit ainda não tem um guia específico para isto, utiliza algo como este vídeo
O A30 utiliza um sensor TCS3701 e ainda não consegui encontrar um substituto. Claro que podes verificar o sensor de proximidade seguindo o fluxograma da Samsung
Como não sabemos a versão exacta do teu A30, verás que a localização de alguns componentes é diferente. Este documento A30 Component Layout All mostra-te todos eles. Utiliza a função de pesquisa do teu leitor de PDF para localizar o componente que queres verificar, por exemplo “R3004”.
''''Enquanto trabalhas no telemóvel, tira muitas fotografias. Quando acabares, imprime estas fotografias e chama um guia para o iFixit. Isso irá ajudar a próxima pessoa que tenha um aparelho com os mesmos problemas que tu. É fácil e divertido criar estes guias. https://ifixit.com/Guide/new A comunidade iFixit vai agradecer-te.
Reparar é uma guerra contra a entropia!
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 40
