Ir para o conteúdo principal
Informações sobre reparo e desmontagem dos fones de ouvido sem fio com cancelamento de ruído AirPods Max.
Is it a poor contact?
When the right earcup is open, the pairing begins, and if you turn the earcup slightly inward, only the right voice will be cut off, and if you turn it a little more, the Bluetooth will be disconnected. When you install the headphones, the pairing is unpaired from the iPhone.
In this case, is it a problem with poor contact of the hinge hardware?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
It sounds like debris on the headband contact pin connecting the left earcup to the right earcup.
Try removing the headband using a SIM ejector tool (This can be found under the ear cushions)
When you pop off the band, the band has what appears to be lightning-like contact pins. Clean those with isopropyl alcohol wipes and reinstall them.
Hope that helps!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
ba_boo será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 13
Ao todo: 231
