Ir para o conteúdo principal
Esta iteração da série Kindle Paperwhite da Amazon foi lançada em 30 de junho de 2015. O Kindle Paperwhite 3ª geração é um tablet com tela de leitura de 300 PPI de 6 polegadas com Wi-Fi. O número do modelo designado é DP75SDI.
My screen is stuck at language setup screen.
Hi Team,
My Kindle was stuck all the time on home screen.
When I press power button it would popup option to restart, shutdown cancel however I was never able to select it.
Out of frustration I followed an article on Internet "Doing Factory reset using computer"
I created File without extension Do_Factory_Restore transferred to kindle performed factory reset.
Now my screen is stuck at language setup page.
  • I am unable to select get started 😑
  • I tried pressing hardreset for 40sec no joy.
  • I tried connecting kindle to computer it shows drive is not ready😓.
  • I have put my self in helpless situation.
Esta é uma boa pergunta?
Pontuação 0
3 comentários:
Is the touch screen working? It could be a screen issue.
por
Touch works on limited area rest feels like screen Is dead
por
It’s possible half the screen is dead , most probable in-fact as it’s a strange screen to be stuck on. Have you dropped it any marks or damage on or around the screen? I’m weirdly convinced my below answer will fix this.
If your not confident you could always take it to a repair shop for second opinion/ repair.
por
Adicionar um comentário
2 respostas
If you cannot do anything on the screen it is most likely a damaged digitiser. This can get damaged by a short fall or bump in the wrong place . Here’s a full guide and what to get.
Substituição da tela tátil do Kindle Paperwhite 3ª Geração
Esta resposta foi útil?
Pontuação 0
Try to turn off the screen using the power button and long-press it for a few seconds. If this doesn't work then try charging it for sometime. Restart your Kindle to resolve the frozen issue.
Pontuação 0
Adicionar a sua resposta
Ashley John será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 13
Ao todo: 333
