Ir para o conteúdo principal
A sanitary disposal device for human waste. No plumber necessary! Fixing a toilet is more straightforward than many people think.
20 Perguntas Visualizar todos
Two toilets acting wierd
I live in a 60s one level home with two bathrooms. One toilet is bubbling. I go in and there is like hardly any water in the bowl. The other toilet has overflowed twice. With no one using it. Help
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @barmstrong
Low water level in a toilet bowl is indicative of a partially blocked sewer pipe or air vent.
If the other toilet is filling instead of draining this also indicates a blockage in the pipes somewhere.
You could try clearing it using a plunger.
If still no good then you may have to try using some other options¹ or calling a plumber as they should have the necessary equipment to clear drains.
¹Option shown only to show example of what you can use - not an endorsement of the service.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Beth Armstrong será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Ao todo: 22
