Ir para o conteúdo principal
The PlayStation 2 (PS2) with the model no. SCPH-900xx is the final stage of development in the PlayStation 2 series. It was released in November 2007.
How to teardown my ps2 slim 90003
the metal shielding for the motherboard doesn't move and is stuck to the CPU how do I take the motherboard out of the shielding? do I need to use heat of any kind? or alcohol?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi!
Please check this guide for removing the motherboard: PlayStation 2 Slimline SCPH-900xx Hauptplatine ersetzen
You do NOT need to use any heat or alcohol to remove the shielding. Make sure that all the screws are out, and then you can take it off. It's normal that it do require a little pressure to take it off.
Please let us know how it goes!
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Matan_Aizenberg será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 190
