Ir para o conteúdo principal
Lançada no Japão a 12 de Dezembro, 2004, na América do Norte a 24 de Março, 2005, e na Europa a 1 de Setembro, 2005.
memory card not recognised
Hi,
My psp 1000 doesn't recognise my memory card. All I get is the orange light blinking and "there is no memory card inserted" when trying to access it. I've tried another card, although not new, and had the same result. I don't know whether to strip down or try to get it repaired.
Any advice would be much appreciated.
Many thanks,
Nick
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi Nicholas!
Okay first it's important to try a memory card which you know for sure that it works 100%.
If not, buy a new one or test it in another PSP to see if it works.
If you did and it still doesn't work, then your memory card reader need an replacement... This is not easy and you need to solder it out and solder a new one in.
To give you the idea about how it works > https://www.youtube.com/watch?v=IKImM8FW...
Part: https://www.ebay.co.uk/itm/393992094813?...
Please let us know how it goes! Hopefully you will get it fixed!!
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Nicholas Hall será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 16
Últimos 30 dias: 99
Ao todo: 1,359
