My display is not working
Esta é uma boa pergunta?
@swetagiri @dhananjayp58320 if this is isolated to your display, change it first. Once you have a new display and it still does not work, you can always check further, but until you have changed it, everything else will only be a guess. A new display will give you a known-well starting point for further troubleshooting.
Since iFixit does not yet have a specific guide for this, use something like this video Replacement LCD's are readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 21
Ao todo: 122
Hi , what happened to it? Does the phone do anything.
por Daniel
My mobile display is not working
por Dhananjay Pratap Sahoo
Mobile display is not working
Is it black screen nothing or can you hear and feel sounds and vibration when you connect to a laptop or turn off and on. The point being is the phone alive or not? If phone is showing lights/ sound or vibration it’s screen related .
por Daniel
Screen related ..OR you did work with battery connected in which case try removing and reseating the battery connector.
por Daniel
