Fader is loose, causing flickering
Hi, I recently opened up my ep-133, there is something wrong with the fader. When I use the pads to play a sequence there is flickering caused by wiggle in the fader. It appears the fader is loose or broken. I have another ep-133 unopened (I was planning on keeping it as a collectable) and I'm worried it will have the same issue as they were purchased at the same time.
Can I get a replacement/fix?
Esta é uma boa pergunta?
