Ir para o conteúdo principal
O Explorer 2011 de 5ª geração trazia semelhanças com a construção do conceito Explorer America e inclui uma estrutura monobloco baseada na plataforma D4.
fan cooling not work
fan cooling not work when the car overheat
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Hi,
Not a lot of information here, but if the fans are operating you will need to do some troubleshooting.
The cooling system in a vehicle is a pressurised closed system.
If you have lost water from the system it is possible that you have a leak either from connecting hoses, water pump, radiator or head gasket leaking.
It may help to web search online for “how a vehicle’s cooling system works”
Or “points of failure in a vehicle’s cooling system”.
Other than that, it might be a good idea to visit a radiator repair shop for an assessment.
Hope this helps
Esta resposta foi útil?
Pontuação 0
Thanks..
The fans cooling only rotated or working when switching on air conditioning with speed no.02 .
Update (08/15/24)
connecting hoses, water pump, radiator or head gasket "on leak" & cooling system operated properly.
What about the power is there or not ?
Or relay or fuse is there or not ?
Because it rotated when switching on air conditioning..
Pontuação 0
1 comentário:
I’m sorry, are talking about the fan on radiator or fan on air conditioning inside the car?
por
Adicionar a sua resposta
Habib Alhabib será eternamente grato(a).
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 18
Últimos 30 dias: 43
Ao todo: 424
