Ir para o conteúdo principal
Informações de reparo e desmontagem para o e-reader Clara BW (preto-e-branco) da Rakuten Kobo, lançado em abril de 2024. Identificado pelos números de modelo N365, N365B ou P365.
Need SD card full image
Does anyone have a full SD card image for Kobo Clara HD N249 model? My sd card is working anymore, I need to image a fresh SD cars. I have no previous backup.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
4 respostas
Solução escolhida
Sorry I have not been following the forum for a while. I have used this image. You can download from mu google drive:
https://drive.google.com/drive/folders/1...
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
Hi,
I’ve had a quick look around and found firmware available for download from the pgaskin website.
https://pgaskin.net/KoboStuff/kobofirmwa...
There seems to be lots of options for firmware upgrades for different models.
Hope this helps
Pontuação 1
3 comentários:
This is a good tutorial on flashing images and using the right formatting tool (windows won’t work apparently)
https://m.youtube.com/watch?v=hRdV5ukt_Q...
por
hi. How can i burn the image? is a zip file with other file inside
por
did you found something ?
Pontuação 0
Yes, I have found a working image. A friend of mine helped me flash it and it works.
Pontuação 0
14 comentários:
hi! i have the same need.. full disk image for my n249 clara hd. can someone help me
por
Hello, same problem for me, would someone charitable please send me a picture for my Clara HD, thank you.
por
@jmrousseau Did you get a response?
por
no answer unfortunately:(, you any luck?
por
@jmrousseau oui j ai recu le liens d un autre forum
por
Exibir mais 9 comentários
Adicionar a sua resposta
Ozzy Aslan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1,940
Últimos 7 dias: 1,997
Últimos 30 dias: 2,275
Ao todo: 7,225
