Ir para o conteúdo principal
O Raspberry Pi 4 é um computador de placa única versátil desenvolvido pela Raspberry Pi Foundation e é a quarta iteração da linha de produtos Raspberry Pi.
USB ports are dead
Hi guys. I have a RaspberryPi 4B 4GB (newer version) that had 9V instead of 5V put through the USB-C power input according to owner.
Surprisingly it boots and works, but ethernet and USB ports are dead. I replaced the BCM54213PE and VL805 chips I took from a donor board - ethernet works fine now, but no luck with USB.
I also replaced the crystals next to both of those chips - didn't help either.
Any ideas what else I should check?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Fixed it in the end :) So in total I replaced both chips and also quartz crystals next to them on both sides, then also replaced a diode next to the Ethernet port and USB 3 and two chips that look like filters between the BCM54213PE and PoE.
None of that actually did the trick in full, so then I reflowed VL805 IC and voila - "we have picture" (c) Sorin :D
Esta resposta foi útil?
Pontuação 1
Did you post your question in the Raspberry Forum area?
I would check the power side of the USB sockets is power getting through? Does a powered USB hub allow the USB device to work?
Pontuação 0
1 comentário:
Oh absolutely, thanks, but actually I already figured it out :) thanks for the heads up anyway :)
por
Adicionar a sua resposta
in_sympathy será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 21
Últimos 30 dias: 79
Ao todo: 1,096
