Ir para o conteúdo principal
Suporte para a calculadora Texas Instruments TI-84 Plus.
Calculator seems to be unresponsive
My calculator turns on and shows the ram cleared after turning on and then when you try to input anything the cursor just gets stuck and hangs. Nothing happens after that. it is unresponsive and does not responds to any input given and just stays blank. i have removed all the five batteries and replaced but still the same. when i try to connect it with my laptop it not being detected by the software.
Imagem
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
are you saying some of the keys work and it locks up after hitting those keys?
por
no after hitting the on button it locks.
por
Adicionar um comentário
1 resposta
Check the I/O port for any debris. Sometimes dirt will confuse and freeze the calculator.
You can try an OS reinstall. Take out one battery then hold [Stat] while putting the battery back in. It should say something like 'send OS new' or 'waiting for OS'.
Now plug the calculator into your computer using the USB cable and send the OS. You can download it from TI's website or directly from TI-Planet: http://ti-pla.net/a2111
It will take a few minutes to install.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Yunus Panthodi será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 31
Ao todo: 396
