My display is broken
I have a broken display. First it was only a black line in the middle. But now the whole display turned black. Is it possible to change it. If so where can I buy a new one
Esta é uma boa pergunta?
@mohamedbalmehdi it might not be the display since it started off "only a black line in the middle". Check the ribbon cables connecting to the driver board of the display. Take the back cover off and take a look at all the boards etc. Check for anything unusual. Post some well focused, large pictures of your boards with your question. That way we can see what you see and hopefully help you out further. Also, let us know what the exact model number for your TV is. It'll be on a label on the back panel
Replacement screens will be hard to find and these are expensive. Once you have the back cover off, there will be a label on the backside of the display. It will have the maker as well as the proper panel number on that. Do a online search with those number sand see if you can find a good used panel for a good price.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 46
