Ir para o conteúdo principal
Released 2020 with Snapdragon 720G SOC Sold in India as the Note 9 Pro Max
Why is my back camera is not working?
When launch the back camera then screen just show black and capture button not working, but if i switch to front camera it's work normally
Esta é uma boa pergunta?
Pontuação 2
4 comentários:
After update camera not working
por
My camera not woking
por
My phone is redmi note 9 pro max and best camera but abhi camra open kar raha hu to block screen show ho Raha hai please answer me
por
@himanshusaroj what have you already checked and what have you tried?
@himanshusaroj aapane pahale kya jaanch liya hai aur aapane kya prayaas kiya hai?
por
Adicionar um comentário
1 resposta
@mandrakishand first check all of your settings and updated all of your software. Because those things you always want to do first. Then you want to try and start your phone in Safe mode and see if the camera works in safe mode. If it does, you know the issue is a third party app that is blocking your camera. You would have to remove the downloaded APP's until you find the one that causes this. To place your phone in safe mode, and when the phone is turned on, long press the volume down key to enter the safe mode. After entering the safe mode, the word "safe mode" will appear in the lower left corner of the phone screen.
If even in safe mode your camera should not work, it may be time to replace it. Since iFixit does not yet have a specific guide for that, use the one from here It is written in Spanish, use a browser that will do the translation for you, if needed. Replacement cameras are available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Mandra Kishand será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 19
Últimos 30 dias: 68
Ao todo: 1,430
