Ir para o conteúdo principal
Informações de reparo para secadoras LG.
Timer won't shut dryer off
I have the same problem on an LG DLE4870W dryer. The On-Off button and the Pause-Start button seem to work normally, but the drum continues until I shut it off at the breaker.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Hi @duanedecker
Try running the diagnostic tests and check if any error codes are displayed when testing the various functions of the dryer.
Esta resposta foi útil?
Pontuação 0
Define what you mean by "normally". If the drum doesn't stop, how is that normal?
The drum control is separate from the heat control. If the drum doesn't stop, the part that runs it, probably a relay, is sticking.
That could be because the signal to the relay is malfunctioning or the relay itself is bad.
If turning on the breaker again does not restart the drum, then it is more likely the relay control is malfunctioning.
Power is removed from the relay by the control or the breaker. So, if it restarts after turning off/on the breaker, the relay is stuck.
If not, it is the control.
Pontuação 0
Adicionar a sua resposta
Duane Decker será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 23
Ao todo: 382
