Ir para o conteúdo principal
O Xbox Elite Wireless Controller Series 2 foi lançado em 4 de novembro de 2019 e é compatível com os consoles Xbox One, X e S, além de PCs com Windows 10/11. Modelo 1797.
Non-responsive with battery connected
Have a strange issue. My elite 2 controller is completely non-responsive when the battery is connected. Won't power on, charge, or anything. BUT it works when plugged in via usb without the battery connected. As soon as I reassemble the back plate and connect the battery, the controller is completely dead.
Useful diagnostic info:
  • battery is delivering power and not damaged
  • no liquid damage to controller
  • no visible corrosion on battery connectors
What is going on????
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Are you using a battery pack? Or just 2 AA batteries? Did you tried both to test the controller? Is the controller up to date? When using a battery pack, which brand? The one from Microsoft?
por
This is an elite series 2...the battery is built-in, not AA replaceable. The battery is original.
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi Matthew! Sry! Okay the easiest thing to try is a new battery pack and see if that solves it! If not, it’s motherboard related. Controller is up to date?
Esta resposta foi útil?
Pontuação 1
2 comentários:
The controller is up to date. I just put the controller back together and while securing the back plate onto the board housing the controller turned on. Once I screwed the back plate onto the housing completely, the controller is now no longer responsive. Could there be a faulty or loose connection? The three pin battery terminal doesn't appear damaged.
Thoughts?
por
Hi! Could be, or something is causing a short. Can you check if the screws are not touching the motherboard? Also check the cables to see if they are free when closing the back plate.
por
Its possible you are screwing the screws too tightly wgen you reassemble the controller. Try to loosen them a little. It might work
Pontuação 0
1 comentário:
Any fix? I have one with the same problem
por
Adicionar a sua resposta
Matthew Riordan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 18
Últimos 30 dias: 61
Ao todo: 588
