Ir para o conteúdo principal
Roupas de frio Patagonia que mantêm você aquecido em dias frios e seco em dias chuvosos. A dificuldade de reparo varia desde o simples conserto de rasgos até o reparo mais complexo de divisórias.
Drawstring is tearing through jacket fabric
Drawstring in my patagonia puffy hoody is tearing through fabric on waist.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
@mike85647 if anybody on here knows, it'll be @mariaparker The iFixit textile repair Guru
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Thanks @oldturkey03 :) @mike85647 It's probably best to reinforce the part where the drawstring is wearing through. You could either sew a strip of fabric onto it (should work similarly to the procedure of sewing a patch onto a pillow, see my guide here), or attach a strip of sticky fabric. There are iron-on fabrics and patches you could use, in that case be careful not to melt the fabric of your jacket if it's made from artificial fibers like nylon or polyester - put a tea towel or a sheet on top before you start ironing.
But you can also get stick-on patches that you don't have to iron on (this one is an example in a German store), that would be better if your jacket is made from nylon, polyester or other artificial fibers. If your jacket is mostly cotton, an iron-on patch should work fine.
Just to be sure, could you upload a picture of your jacket?
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Mike será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 34
Ao todo: 261
