Ir para o conteúdo principal
O Samsung Galaxy A52s é uma variante aprimorada do Galaxy A52 da Samsung.
How to replace a broken vibration motor?
Some time ago I noticed the vibrations of the phone being kind of strange like the vibration motor was loose inside the phone or something. The vibrations rattled even in my hands. Now, however, the vibration is gone entirely. Even when I test the vibrations in the diagnostics panel, I get nothing.
I live in a region where Samsung certified repair shops are in limited numbers. There's only one in my city and they told me that they are not sure if it can be fixed. Is there something I can do to fix it or do I just have to live with it?
Thanks!
Esta é uma boa pergunta?
Pontuação 0
1 comentário
HOW TO FIX THE VIBRATION ON MY SAMSUNG A52s ?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi,
There’s an ideal iFixit guide for you to follow here:
Substituição da tela do Samsung Galaxy A52s
It’s a screen replacement guide which includes steps to remove vibration motor, but you’ll only need to go as far as removing the top mainboard.
The vibration motor isn’t mentioned until after the battery is removed - if you watch the battery being removed he then tells you about the vibration motor at the upper end where the mainboard was removed.
Hope this helps
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Daedalus308 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 18
Últimos 30 dias: 65
Ao todo: 1,887
