Cara menyambung kabel AV lewat hp
Agar bisa mendengarkan musik lewat tv
Translation Indonesian - English
How to connect AV cable via cellphone
So you can listen to music via TV
Esta é uma boa pergunta?
@rizal76689 a TV really does not make a good audio amplifier. This TV in particular does not have a lot of the capability that newer TV's have.
This is not to say that it might not work. You can always try and get a audio cable that has a 3.5mm audio jack on one end and output to two RCA jacks. Something like this
Then connect the 3.5mm jack to the headphone jack of your phone. Connect the 2 RCA jacks to the RCA jacks in the front panel of your TV (L and R audio jacks. Now, here comes the part that'll be interesting to setup. You would have to consider the audio in as you would connect a VCR etc. to this TV check page 32. Turn your TV on and set the input accordingly. For the rest of the settings on your TV go to page 62 of the Sony KDF E60A20 User Manual Give it a try and see what happens.
Translation
@rizal76689 TV tidak bisa menjadi penguat audio yang bagus. TV ini khususnya tidak memiliki banyak kemampuan yang dimiliki TV baru.
Ini bukan berarti TV ini tidak bisa berfungsi. Anda selalu dapat mencoba dan mendapatkan kabel audio yang memiliki jack audio 3,5 mm di salah satu ujungnya dan output ke dua jack RCA. Kira-kira seperti ini
Kemudian hubungkan jack 3,5 mm ke jack headphone ponsel Anda. Hubungkan 2 jack RCA ke jack RCA di panel depan TV Anda (jack audio L dan R. Nah, inilah bagian yang menarik untuk disiapkan. Anda harus mempertimbangkan audio seperti Anda menghubungkan VCR dll. ke TV ini, periksa halaman 32. Nyalakan TV Anda dan atur input yang sesuai. Untuk pengaturan lainnya di TV Anda, buka halaman 62 dari Sony KDF E60A20 User Manual Cobalah dan lihat apa yang terjadi.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 10
