Ir para o conteúdo principal
Repair and disassembly information for Google's Pixel 6 smartphone, released in October 2021. Identified by model number GB7N6 and G9S9B16.
Correct screen for model?
My screen is broken but I don't know how to find the model number. Does the screen differ based on the model?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi @jghunter
All the models have a 6.4" amoled display so chances are the same one is used for every model variant.
Here's the ifixit Substituição da tela do Google Pixel 6 guide, that may help.
ifixit also sells the OEM display assembly
Esta resposta foi útil?
Pontuação 1
Hi,
If you can still use the screen, then go to settings/about and the details will be there.
If you have no access through the screen then you can go to this link
https://www.phonemore.com/models/google/...
You should be able to identify your model from there.
Hope this helps
Pontuação 0
Adicionar a sua resposta
Jeremy Hunter será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 111
