Ir para o conteúdo principal
Guias de reparo e documentação para o smartphone Google Pixel 5. Lançado em 15 de outubro de 2020. Número do modelo: GD1YQ, GTT9Q
Adhesive misaligned - Can it be adjusted?
Hey everyone, i could use some help - I recently replaced my battery with the iFixit kit and used the included screen adhesive, but I didn't realise until too late that I accidentally misaligned the adhesive on the bottom right corner, because everything else is firmly sealed, but that corner is slightly disconnected from the back piece. Is it possible to take the screen back off and realign it without more adhesive? Or will i need to replace all of the adhesive? Thank you for your help :)
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi Brandon,
You could try to realign the adhesive, although in my experience, this rarely works.
You'll probably have to use new adhesive if you want an optimal seal. (Just remember to remove the old adhesive!)
Hope this helps, let me know if you have any other questions :)
Esta resposta foi útil?
Pontuação 2
1 comentário:
Thank you for your help! I appreciate it :)
I looked online and found a good alternative adhesive, so I'm going to try again soon. Wish me luck!
por
Adicionar a sua resposta
Brandon será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Ao todo: 128
