Ir para o conteúdo principal
Informações sobre reparo, desmontagem e resolução de problemas para a versão redesenhada e mais fina do PlayStation 5 da Sony, lançada em novembro de 2023. Apelidado de PS5 Slim, ele possui 1 TB de armazenamento padrão e uma unidade de disco modular.
Is there a Bluetooth antenna?
Hello! Looking to upgrade the antenna for the Bluetooth (better controller range when ps5 is stored inside a rack).
Wondering if the blue and white cable shown in the teardown video is the Bluetooth antenna
Thank you
Esta é uma boa pergunta?
Pontuação 2
1 comentário
@eddietsang have you tried the Bluetooth mod yet and have you been successful at it? Iam looking to do the same with my ps5 slim.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi Eddie!
The blue and white antenna cables are basically fused together on some metal (and this one is attached to the PSU).
Here you can see where it comes together (the part): https://www.ebay.com/itm/196416264711?no...
Those are for the WiFi and Bluetooth together.
Esta resposta foi útil?
Pontuação 3
3 comentários:
Ooh I see. Can you explain what you mean by "this one is attached to the PSU"?
The antenna on eBay you referenced is the exact one I see after opening up my Slim. I installed an external antenna in place of this... So to confirm, are you saying the Slim only has one antenna(wifi and Bluetooth together) as opposed to 2 in the original ps5?
Thank you
por
Hi Eddie!
The metal piece is attached to the power supply! But this is only for the PS5. For the PS5 Slim it’s attached to the the side (opposite site from the power supply). Yes! The original PS5 have 2 antenna’s. blue and white, and black and white. The PS5 Slim only have the Blue and White ones. Wifi and bluetooth are combined. Same for the original PS5, but do have an extra antenna for more range.
por
And so can we just pull the blue cable an attach an external 2.4 antenna (say 6db ?)
por
Adicionar a sua resposta
Eddie Tsang será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 13
Últimos 30 dias: 55
Ao todo: 1,847
