Ir para o conteúdo principal
The Samsung S860 is a high resolution digital camera with 8.1 megapixels, 3x optical zoom, Samsung SHD Lens, 2.4-inch LCD screen, and Digital Image Stabilization (DIS).
Why will my camera not stop saying "select USB" when no USB is plugged
My camera says "select USB" everytime I turn it on even though I don't have a USB cord plugged in. I've tried deleting all the images on the memory card and have also shut it down and restarted it, but it won't stop saying this.
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Hi @alexknoke
Try a power refresh and check if it resolves the problem.
Turn off the camera and then remove the batteries from the camera.
Press and hold the Power button for 30 seconds and then release it.
Reinsert the batteries, turn on the camera and check if it is now OK.
por
Hi @jayeff I just tried that and it didn’t seem to work. do you have any other suggestions?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @alexknoke
Here's the Samsung S860 Training manual.
Go to p.13 and check if factory resetting works.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Alex Knoke será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 23
Ao todo: 620
