Ir para o conteúdo principal
O HTC Desire é o primeiro smartphone da série Desire desenvolvido pela HTC.
How to replace cracked glass screen?
Hi,
I have a HTC Desire A8183 with a cracked glass screen (front) that I would like some help in replacing.
I have never tried to fix anything before so as much (simple, easy to understand) information as possible would be very much appreciated!!
I also need to find out where I can buy a replacement screen from too!
Thank you in advance,
Laura
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
Laura, here is a video that should help you to accomplish your task. If you are more of a picture step-by-step person check on here. Replacement parts are available here and here and of course here. Hope this helps, good luck
Esta resposta foi útil?
Pontuação 1
Hello,
I have the same problem (cracked glass screen) but, I have a HTC Desire X. So I wondering if I can replace just front glass or must replace touch display too (touch display works normaly!)
Thank you for your information!
Jaka
Pontuação 0
Adicionar a sua resposta
Laura será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 8
Ao todo: 22,990
