Not turning on after battery replacement
Hey, after replacing the battery my laptop has not been able to turn on. The replacement seemed to go well as I simply replaced the part and put cable in but somehow the laptop is giving issues turning back on.
Here is more specific details on how the laptop is reacting:
When powering on, fan spins and power light goes on but no other signs of life, no keyboard backlight or display
I tried putting old battery in and it doesn't work either, doing same issues. I tried running off charger only while battery is removed and it also acts the same.
Laptop power light turns on when on charger, unable to turn off. Charging light works and shows battery status correctly while charging. Display, keyboard backlight don't turn on, nor do the fans at full speed (although I noticed one of them spinning while I plugged in charger.). All the ribbons and connections look okay so I'm not sure why it isn't turning on.
Esta é uma boa pergunta?
