Ir para o conteúdo principal
Repair guides and disassembly information for the Samsung Galaxy A51 Android smartphone. Released in January of 2020.
20 Perguntas Visualizar todos
My Samsung A 51 over heating when charging
Why is my phone heated while charging, the charger also gets hot
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@seantrim2008 the charger could be getting hot because your phone is drawing a higher amount of amps. For now you want to consider replacing the battery. A failed battery can be the cause of that. The only other thing you do want to take a look at is your charging board and the charging port flex. Make sure those are properly connected, show no corrosion or tears.
Here are the iFixit guides for that Samsung Galaxy A51 Battery Replacement
Samsung Galaxy A510F, remplacement du PCB USB, jack et boutons
Imagem de Samsung Galaxy A51 Battery
Guia
Nível de dificuldade:
Moderado
45 minutes - 2 hours
Imagem de Samsung Galaxy A5 (2016) USB connector PCB, jack and buttons
Guia
Samsung Galaxy A510F, replacement of USB PCB, jack and buttons
Difícil
2 hours
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Seantrim2008 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 12
Ao todo: 87
