Ir para o conteúdo principal
O Acer Chromebook 15 CB5-571-C09S é um laptop branco criado pela Acer Inc. e operado pelo Google Chrome. Este laptop foi lançado em março de 2015 e possui uma tela de 15,6". Ele pode ser identificado pelo número de modelo CB5-571-C09S.
hdmi port no working?
hdmi output not working?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
This is quite difficult to answer without more information in regards to what's not working specifically.
Although there are three probable causes:
  • The display drivers in the device are corrupt and need a reinstall. Considering it's a Chromebook, I'd rather just go with reinstalling the entire machine.
  • The HDMI port is damaged. If this is the case it can be replaced, but might not be worth it.
  • A motherboard issue. In this case, you're better off to just buy a new computer if this is a major issue for you. If the issue lies within the motherboard, it would require microsoldering knowledge and a lot of work to fix, and would definitely cost more than purchasing a new computer.
Have you tried using another cable or/and monitor? The problem might not necessarily lie within the computer.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Danny Smyth será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Ao todo: 203
