Ir para o conteúdo principal
Gerador inversor com Bluetooth RYOBI 2020 - 2.300 watts de partida e 1.800 watts de operação. O número do modelo é RYI2300VNM.
overloading with nothing plugged in
Why is my Ryobi 2300 bta generator all the sudden overloading soon as it's started with nothing plugged in, also I noticed that the display indicates that it's pulling more watts to run the same load that it was previously using less watts to run I have replaced carb, sparkplug oil, fuel filter air cleaner and the problem still present
Esta é uma boa pergunta?
Pontuação 2
2 comentários:
Do you have the GENControl app on your phone? It might give more information.
por
@nest2g Yes ,it only displays fuel level watts used and kill switch function there's no diagnostics option
por
Adicionar um comentário
2 respostas
Esta resposta foi útil?
Pontuação 0
Have you figured out any additional information , looks like I have the same issue , id hate to have to tear this thing apart I only used it 4 times
Pontuação 0
Adicionar a sua resposta
Robert Alexovich será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 44
Ao todo: 852
