Ir para o conteúdo principal
Crashing to blue screen
When my computer starts at times it takes one or two minutes and it crashes to blue screen saying critical process died. Also after starting the computer directly freezes and does not execute any command but the mouse would be atleast moving on the screen and if you try to click on anything it will crash after 20 seconds. It started after i plugged a Ucom joystick and after a series of crashes it goes to uefi settings
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Well I will suggest you to do the following:
  1. Shut your PC down. With the BSOD displayed, press and hold your PC's power button to force shutdown you system
  2. Disconnect any devices which is connected to your system
  3. Reboot in Safe Mode.
  4. Uninstall the ant recently installed software or game.
  5. Update the driver.
  6. Run a malware scan.
  7. Check for damage.
  8. check your PC's RAM.
Esta resposta foi útil?
Pontuação 0
1 comentário:
I've done that but now i can use it for a little while and it freezes continiously until it crashes again
por Compartilhar
I have an Acer Aspire ES1-111 laptop and I am experiencing a blue screen when logging to the desktop please help me
Pontuação 0
Adicionar a sua resposta
Brido será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 6
Últimos 30 dias: 25
Ao todo: 339
